hi.
everything works perfectly, but every time windows10 is opened, I get the sync error: missing pyhton27.dll (error code 5). I reinstall odrivesync and it’s ok … until I shut and beguin again … what to do ???
thanks for your help.
JJ
Hi @jeanjacques.palmade,
It sounds like something is removing that file. Do you have any anti-virus running? Can you check to see if maybe some odrive files are being falsely flagged?
