macOS 10.13.6 - odrive 6420 - Sync not working, now "credentials not valid"
Ok, I’ve seen that the folder I wanted to access via WebDav changed the login-credentials. I’ll try to enter those in odrive.com. Probably that was the issue!
Hi @mx1,
Were you able to get this resolved with the new credentials?
Hey Tony,
yes, thank you. I entered the new credentials in odrive.com and the sync worked.
Just a suggestion: Could the odrive-app give a feedback if the login failed?
