I recently copied files from laptop to NAS and restored sync to Amazon Prime Photos. I was able to sync the folders from the NAS without re-uploading the files and the folders indicated successful sync with the blue badge.
A few days later, the folders do not seem synced now, and there is no blue badge indicating that the sync is still active. Is there a reason that the sync would be lost? The photos are still intact locally and on Amazon.
Hi @njelbe,
Apologies for the delay. I missed this one in the shuffle.
I took a look at the diagnostic and the “sync to odrive” folders you have defined are all listed as “Missing”. This can indicate that the volume wasn’t available when odrive started, or the remote side of the relationship changed in some way.
Can you go to the odrive menu, click on one of the folders listed under “sync to odrive”, and see what it says?
Hi @njelbe,
If you restart odrive, does it stay that way? What if you click on one of the entries that shows missing? It should pop-up a window that gives some additional info and some options?
Hi @njelbe,
You should not have to re-upload your photos. Reconnecting those “sync to odrive” folders will pick up where it left off, once it has scanned the data.
