I just sent a diagnostic. I have a file that is stuck in Waiting. I imagine the problem to be the filename length of 233 characters (including the extension). This filename and future ones are automatically generated by an IFTTT recipe.
Hi @acsentell,
You are correct. The filename is too long to bring down on Windows. If you shorten it a bit it will correct the issue.
I moved this discussion to its own thread, here.
