I’m hopping to get Google Drive in Ubuntu using Odrive to keep a couple of folders in sync (it would be selective sync, don’t want all my google drive content in the machine).
I manage to follow the cli odrive agent guide to get the folder I want to sync, but its content remain as placeholders. What is the command to get all files and folders within a sync folder to also sync?
Hi @mario,
You only need the odrivecli.py file, so you can grab that individually if you want. The CLI recursive sync is single-threaded, though, so the one-liner is actually going to be more performant, if you are downloading lots of stuff.
For making typing easier you can setup an alias, like this: echo "alias aliasname='command'" >> ~/.bash_aliases && source ~/.bash_aliases
So, for example: echo "alias odrivecli='python $HOME/.odrive-agent/bin/odrive.py'" >> ~/.bash_aliases && source ~/.bash_aliases
hi, i can’t understand what’s the utility of odrivecli.py. i’m on ubuntu 17
whit this comand: "$HOME/.odrive-agent/bin/odrive" sync "$HOME/path-to-folder.cloudf"
i get same results of odrivecli synch "$HOME/$HOME/path-of-folder.cloudf"
no recursion, i get only path-of-folder and not subfolder and files sycnrhonization. Where’s my mistake?
i also notice that on the bash script: exec 6>&1;num_procs=10;output="go"; while [ "$output" ]; do output=$(find "$HOME/Cloud/path-to-folder/" -name "*.cloud*" -print0 | xargs -0 -n 1 -P $num_procs "$HOME/.odrive-agent/bin/odrive.py" sync | tee /dev/fd/6); done
i have to add “phyton” exec 6>&1;num_procs=10;output="go"; while [ "$output" ]; do output=$(find "$HOME/path-to-folder/" -name "*.cloud*" -print0 | xargs -0 -n 1 -P $num_procs phyton "$HOME/.odrive-agent/bin/odrive.py" sync | tee /dev/fd/6); done
Hi @william.melatini,
The basic odrive CLI doesn’t offer recursion, but you can use a script like the one you have listed. The reason you needed to add ‘python’ to that, is because you are calling the python script instead of the binary script. You can use the binary version like this:
“$HOME/.odrive-agent/bin/odrive”
exec 6>&1;num_procs=5;output="go"; while [ "$output" ]; do output=$(find "$HOME/path-to-folder/" -name "*.cloud*" -print0 | xargs -0 -n 1 -P $num_procs "$HOME/.odrive-agent/bin/odrive" sync | tee /dev/fd/6); done
with your script recursion not works, i’m missing somethings?
With this comand: odrivecli synch "$HOME/$HOME/path-of-folder.cloudf"
would i sync all files and sub folder?
with bush script all seem to works fine except for this notices at the end: usage: odrive sync [-h] placeholderPath odrive sync: error: too few arguments
odrivecli will not perform recursion on its own but the script can. Make sure the folder you want to recursively sync has been synced once so that you are performing this on an actual folder and not a placeholder. Since the command is using find to recurse through the structure, it needs to start with a real folder.
This is the command I use on my own system: date; exec 6>&1;num_procs=4;output="go"; while [ "$output" ]; do output=$(find "[insert path of the folder you want to sync]" -name "*.cloud*" -print0 | xargs -0 -n 1 -P $num_procs "$HOME/.odrive-agent/bin/odrive" sync | tee /dev/fd/6); done; date
For [insert path of the folder you want to sync] replace that with the full path to the folder you want to sync. Again, make sure that folder is not still a placeholder (.cloudf). For example, if you wanted to sync all of the content in the folder /home/ubuntu/odrive/Amazon Cloud Drive.cloudf You would perform these steps:
I’m on Ubuntu and I need to download contents from Amazon Cloud Drive
I can use only Odrive CLI, the big question is how to do it?
I have thousands of directories there, so syncing everything by hands is not an option
need to be able to do something odrive download / /path/to/download
