I recently started to use odrive with AWS for backups and finding it very nice. I have having a few issues though.
I’m using the CLI on Linux with AWS with the backup options. I understand that “backup” isn’t formally released yet and hoping that reporting these issues can help with th development and backup.
- Ubuntu 14.04.5 LTS
- Python 2.7.6
- Odrive, current 64 bit version, prod 924 per “status”. I’m using the free version. If the paid version will address any of these issues I’m happy to do so.
Is there a way to turn on verbose logging to better troubleshoot issues?
Is there a way to set a schedule? odrive backs up every hour and I’d like to change that to once per day in the middle of the night.
I’m seeing a small number of repeatable but unexplained errors. I’m hoping verbose logging will help isolate the problem. Example below. Removing the file on ACD, or renaming the file locally doesn’t resolve the issues. The errors continue indefinitely. The file names are unique and not related to case.
21 Feb 09:02:13AM INFO Unable to back up file /home/downloads/www.ubuntu.net/netatalk/netatalk-2.2.2/man/man1/Makefile: Amazon Cloud Drive error.
21 Feb 08:01:52AM INFO Unable to back up file /home/mdecorte/linux-config/docker/squeezeserver/chef/chef-repo/cookbooks/AirSqueeze/files/default/AirSqueeze/strings.txt: Amazon Cloud Drive has detected a conflict.
- If the directory that is being backed up has any symlinks, the entire backup for all files fails. It would be nice if sym-links were supported, but lacking that they should be skipped over with the balance of the backup continuing. The work around is to remove the sym-links in the source but this is problematic.
20 Feb 09:17:17AM INFO Backing up /home/mdecorte/linux-config/chef.
20 Feb 09:17:17AM INFO An unexpected error occurred while backing up.
- a /etc/init startup script would be helpful. I’ve written one but after a reboot, the odrive agent is running per ps but it doesn’t respond to client commands such as status. Not sure why. verbose would be helpful.
