I like the idea of ODrive using stubs, and ideal would be the ability to allow, say 50GB for downloaded files, but for odrive to automatically manage this “cache”.
I see there’s a manual unsync option (premium only). Does though the above feature exist (using free currently).
Hi @nigel,
We have auto-unsync rules that you can apply globally that will auto-unsync files that have not been used within a certain period of time. You can find out more about that here:
That’s an cool idea @nigel! Automatically manage cache with a certain limit could be an option in the auto-unsync feature. For exemplo: Just auto-unsync files from odrive folder if the limit of 100GB is exceeded.
I could see adding to this with an option to look at directory structures that are over a certain size (using du in bash, for example) and then applying unsync to that structure.
