after a while, uploading slows down to a crawl. Restarting the agent recovers the speed for a while. I have large files (~50GB).
Is there a way to disable the upload throttling?
Regards,
–Saku
Regards,
–Saku
Hi @setala,
odrive’s engine tries to limit large file uploads to one-at-a-time. There are cases where this limit is not enacted on startup, depending on the environment and structure.
This may be what you are seeing, where you are uploading multiple large files concurrently after restart and then it moves to one-at-a-time after a while. There isn’t a way to change this, currently.
Ok, thanks for your reply. How big is a “large file”?
–Saku
Hi @setala,
A large file is considered anything over 100MB.
