If the passphrase is compromised is there a way to change it?
Since the encryption of the files is predicated on the passphrase, you would need to unencrypt and reencrypt everything. There isn’t an automatic process for this, but you can sync everything down, create a new encrypted folder and move the content into there.
That is what I am figuring out as a I am working through the issue. This solution definitely works but is a bit laborious. It would be nice to just have an automatic way to change the passphrase and then have odrive automatically decrypt and re-encrypt locally and then change the sync configuration back to the way it was before (ie sync vs unsync folders and full sync settings etc.).
