Is odrive desktop supported on MacOS Sequoia beta? 😬
Hi @kenlefeb,
You can use the included python CLI to send commands, including unsync, from the terminal.
For example:
python3 ~/.odrive/bin/7423/odrive.py unsync "/Users/t/odrive/Dropbox Business/temp"
Would unsync the temp folder in my Dropbox Business account.
Just a heads up - I updated to Beta 2, and the issue persists…
Hi @matt.nye and @kenlefeb,
This is a bit of a shot in the dark, but I wanted to try something.
This command sequence will copy the odriveapp.app file into the user’s Applications folder and then go through the extension registration. My thinking is that the new version of MacOS may be picky about where the extension is located…
echo "Existing odrive plugin: "; pluginkit -vvvmA | grep odrive; echo "Removing odrive plugin and listing (should be none listed): "; pluginkit -r ~/.odrive/bin/*/odriveapp.app/Contents/PlugIns/*; pluginkit -r ~/Applications/odriveapp.app/Contents/PlugIns/*; sleep 5; pluginkit -vvvmA | grep odrive; echo "Copying odriveapp.app to ~/Applications"; cp -R ~/.odrive/bin/7423/odriveapp.app ~/Applications/; sleep 15; echo "Adding odrive plugin and listing: "; pluginkit -a ~/Applications/odriveapp.app/Contents/PlugIns/*; sleep 5; pluginkit -a ~/Applications/odriveapp.app/Contents/PlugIns/*; sleep 5; pluginkit -vvvmA | grep odrive; echo "Enabling odrive plugin: "; pluginkit -e "use" -i "com.oxygen.odriveapp"
Can you give that a shot and see if it changes anything?
I’ll give that a shot over the weekend and let you know. Thanks!
Great guess! That gave me the sync options in Finder!
Me too!
Thank you so much for your dedication to helping us figure this out! You are awesome, Tony!
Great! Thanks for trying that @matt.nye and @kenlefeb. I really appreciate your patience and assistance with this.
Now we need to look at product changes to account for this.
not starting at all and see the crash reports each time
Hi @dimitri,
Can you try this version, when you get a chance? odrive
@Tony great thanks for so fast response
It works well - started without crashing and synced all files.
Our latest release has this fix in it:
I can’t sync files after upgrading to Sequoia, why?
Hi @khanraj15274,
Please update to the latest version. See the post above yours.
