Hi there, I can’t sync “My Posts” folder. I get this message Unable to sync My Posts.cloudf.
“That hashtag is not allowed by Instagram.”. Can someone explain what’s going on?
thanks
Hi @iunio,
Apologies for the inconvenience.
Instagram removed access to the API odrive was using for integration. They have a new “basic” API available now, but we have not yet integrated to it, although it is on our list.
Thank you for your prompt reply. Any guess on the timing?
Hi @iuniervo,
I don’t, unfortunately, but I will be sure to ping this thread as soon as we do.
Hello Tony,
Nicely explained the answer.
