Https url link to a companies 365 sharepoint site
Hi There,
As a freelancer I have a guest account on a companies 365 sharepoint.
A few days ago I have started to setup the odrive integration by adding a link to this storage in the web interface. Hence, I have chosen the option to request my access via the domain of the organization. At the very last step it is needed to ask for a companies admin approval so that the odrive app can be used.
I have my doubts whether I will receive the admin approval in terms of the odrive app since this company has that many group regulations.
Thus, I would like to know if I could also mount in odrive an https url link to 365 sharepoint site only, such as https://company.sharepoint.com/sites/projectabc/Shared%20Documents/Forms/AllItems.aspx?RootFolder=%2Fsites%2Fprojectabc%2FShared%20Documents%2FGeneral&FolderCTID=0x0121003859216CACCC1248B27759A48053DB8B.
This would help to overcome this issue with the admin approval which I do not expect to receive.
More than happy to receive help, support and suggestions from you guys.
Best regards,
Sebastian
Hi @sschiller,
Thanks for reaching out.
Unfortunately there isn’t a way to add a link like that into odrive.
Hi @Tony,
Thank you very much for your reply. I guess my use case is a very common one for those who do not have full access to Sharepoint 365 when collaborating with other companies.
It would be great if you could take a closer look at this use case. Probably this could become a very useful feature enhancement for an upcoming version.
Many thanks and best regards,
Sebastian
Hi @sschiller,
Thanks for the follow-up.
The main issue is that our app will need some form of authentication to make API requests to the company’s storage and I don’t think there is a way around that. Even if there was, I don’t think we would want to because that would be a violation of the policies the company has set.
When you access that link, are you required to login, or is the share available to anyone that has a link to it?
