I have a drive that crapped out, but it’s somehow still showing as mounted, I’m using linux and am wondering how to unmount all the previously mounted drives
Hi @leenpaws,
I don’t understand the issue here. Can you provide some additional information?
What mounts are you talking about and how does it relate to odrive?
I have the same problem.
I need to change odrive mount point, using odriveagent on linux.
afaik, It is required to unmount the current localPath before choosing a new one.
But I don’t know the current localPath.
Edit: figured out. using
$ odrive status --mounts
shows the current localPath.
Hi @swat.oc,
Glad you were able to figure it out. Thanks for the update
