Is there a way to set a subfolder never to sync? thnx
Hi @epekarik,
You can use exclusions to tell odrive to ignore certain names and patterns. Here is our default list: https://docs.odrive.com/docs/sync-changes#ignore-list
So, for example, you can add a ~ character to the front of your folder.
We also have advanced feature for defining custom exclusions: https://docs.odrive.com/docs/sync-changes#custom-ignore-listblacklist
Excellent, thank you!
