Hi, I just wanted to ask if there’s any way to make odrive automatically run after a Mac running High Sierra has been restarted? I keep forgetting to run it after rebooting. Thanks!
Hey @adamobren it should be just the same as on Yosemite I believe:
Hi @adamobren,
odrive should set this up automatically for you, but if not @smblythe instructions should assist you. The basic steps are:
- Open System Preferences>Users & Groups
- Select your User ID
- Select Login Items
- Click the lock icon and enter and admin password
- Click the + button and select odrive.app from your Applications folder
smblythe and Tony: Thank you so much!
That was just what I needed!
