How do I know which drive is synced when I right click?
When I right click in windows explorer I get the option “sync to odrive”. Can I force it to sync to amazon drive?
Hi @rudienos,
“Sync to odrive” allows you to create a sync relationship between a folder on your local system and a folder in the cloud. You can read more about the feature here: https://docs.odrive.com/v1.0/docs/manage-sync#section-sync-external-folders
