I used Google Drive so I have a lot of Google application documents which odrive does not seem to be able to handle at all and they clutter up the menu. I am wonder what should be done about this. It would be nice to have it load the link to to the appropriate document in Google Apps as the Google Drive sync does, so I am wondering why odrive doesn’t do this. What does this alert even signify? When I select one of document the message indicates that changes that I made to the document were not preserved and that I need to use Google Drive sync to remedy the situation. If that is case, why do I even bother with odrive at all if I need GDS as well? Absurd.
Even so, why leave these document names in this submenu with apparently no way of clearing them? Is the expectation that I am going to “Delete My Changes” (whatever that means) in order to make the annoying error message to go away? I am just curious as to what the thinking is behind this for a tool that purports to put all file sync under one roof as to reduce overall resource usage, but I am beginning to wonder if in fact this is even the case!
