Windows 10 user using Pro odrive account. I’ve noticed up to and over a gig of memory being used on occasion with odrive and have to restart the app to lower it’s usage. It slowly climbs back up to using the same amount over time. I have attached current memory usage after restarting the app 5 minutes ago.
Hi @ncalvert,
Thanks for reaching out about this. When you look at the odrive tray menu, are you noticing any actions taking place?
Can you also tell me how many links you have and what type they are?
In addition, can you also tell me how many “exposed” files and folders there are inside the odrive folder?
