Unable to sync AmazonCloudDrive.cloudf. You do not have permission.
I used to use “acd_cli” to sync my Amazon Drive. It recently stopped working and it was posted that Amazon no longer allows any third-party apps to use their API - does this include odrive?
Thanks for the quick reply. No errors on the web interface, I can browse the drive contents fine there. I’m not sure what is causing the permission denied error. Both the agent and client are running as root so its not filesystem related (no selinux etc either). I tried both the bundled binary as well as the straight python client, same result.
Hi @blazer0x,
Do you have any other storage account linked? If so, I would be curious to know if they show the same behavior or if you are able to sync them without an error.
Can you also try mounting the odrive folder in a subfolder instead of directly from root? Just want to make sure something funky isn’t happening there.
Nope, no other account linked, If I try to mount a subfolder, it says the path is invalid. For example, at the top level of my Amazon Drive, I have a folder called “BACKUP” (see screenshot here.
./odrive mount /odrive /BACKUP
Unable to sync /odrive The remote path is invalid.
Hi @blazer0x,
To mount a remote subfolder in Amazon the path would need to be “/AmazonCloudDrive/BACKUP/”. I was actually asking the other way though, to mount locally in a subfolder.
So something like: ./odrive mount /root/odrive /
or ./odrive mount /users/user1/odrive /
If you wanted to mount Amazon Drive directly (since its the only linked storage): ./odrive mount /root/odrive /AmazonCloudDrive/
If you wanted to mount a specific folder within Amazon: ./odrive mount /root/odrive /AmazonCloudDrive/BACKUP/
Funny thing, I tried again with just /odrive and that worked too! Not sure what I was doing wrong before. Now to see if I can get the “backup” command to work so I can push some data in
Hi @blazer0x,
I just wanted to mention that the backup feature (as opposed to sync) that is available in the CLI is an early-access version of backup. It works, but it really should be considered a “beta” at best. Just a heads up. Since its all one-way sync, there isn’t risk in using it, but it may have some quirks.
