I have the same plan (Grandfathered Unsync Subscription|) but recently it stoped working. I tryed to refresh the subscription and logoff/login but no results.
Information:
prod 7284
System Mac Mini 2010
MacOS 10.13.6 (17G14042)
Information:
prod 7284
Hi @douglasn,
I had the account team take a look, and you still have the grandfathered subscription.
I sent it in the same day of the problem. No error message displayed.
odrive Status
buildNumber: 7189
product: prod
odriveEmail: douglasn@gmail.com
odriveName: Douglas Negreiros
authorizedAccountSourceType: Google
downloadThreshold: 10.0MB
unsyncThreshold: -1
autoTrashThreshold: -1
xlFileThreshold: never
downloadThrottlingThreshold: unlimited
uploadThrottlingThreshold: normal
odriveFolder: /Users/Doufer/odrive
LocalEventsEnabled: True
RemoteEventsEnabled: True
LocalScanEnabled: True
RemoteScanEnabled: True
generalConf:
suppressTrashNotifications: False
maxDownloadRetries: 3
preventOldDownload: False
ignoreSizeMismatch: False
premiumConf:
maxConcurrentDownloads: 4
blackListPrefixes: [u’.~‘, u’._‘]
blackListNames: [u’thumbs.db’, u’desktop.ini’]
maxConcurrentUploads: 4
forgetEncPassphrase: False
blackListExtensions: [u’.tmp’, u’.download’]
Trash (0):
Not allowed (1):
/Users/Doufer/odrive/Closet Store: created=01:06:00PM, exception=SyncAdapterRequestException(code o_ILLEGAL_ADD_FILE caused by odriveRequestException(code o_ILLEGAL_ADD_FILE - Cannot add folders to this folder.))
Waiting (0):
Active (0):
Uploads (0):
Downloads (0):
Sync folders (0):
Folder sync rules (0):
Blacklist:
Names: com9, com8, lpt8, lpt9, com1, lpt5, com3, com2, com5, com4, icon/r, com6, $extend, nul, current_odrive_status.txt, $badclus, $upcase, $objld, .fcpcache, prn, $mftmirr, .odrive, lpt4, $attrdef, .localized, thumbs.db:encryptable, $volume, lpt7, lpt2, thumbs.db, odrive_user_general_conf.txt, $logfile, lpt1, $boot, $reparse, com7, .ds_store, $secure, icon, lpt3, $bitmap, icon, $mft, odrive_user_premium_conf.txt, .oxygenreserved, .dropbox, $quota, lpt6, desktop.ini, System Volume Information, .lock, .oxygenmeta, con
Prefixes: thumbs.db, .lock, ~, .~, ._
Extensions: .dwl2, .m~, .crdownload, .vpsh, .tmp, .download, .lrprev, .dwl
Contains:
Recently added to remote (5):
/Users/Doufer/odrive/Google Drive/Sites/Mulher Rendeira/Logo/Antigo.png
/Users/Doufer/odrive/Google Drive/Sites/Mulher Rendeira/Logo/Fonte da Logo/Sequel-Sans-www.Dfonts.org.zip
/Users/Doufer/odrive/Google Drive/Sites/Mulher Rendeira/Logo/1x/Sequel-Sans-www.Dfonts.org.zip
/Users/Doufer/odrive/Google Drive/Sites/Mulher Rendeira/Logo/1x/Antigo.png
/Users/Doufer/odrive/Google Drive/Sites/Mulher Rendeira/Logo/1x/Fonte da Logo/Sequel-Sans-www.Dfonts.org.zip
Recent Errors:
2022-04-08_01:00:58PM 123145496715264 123145597673472 RAISED apply_remote_add_folder([u’parentUri=/‘, u"localAttributesTree=localAttr=FileAttributes(id=u’16777223:17422542’, name=u’Closet Store’, isFolder=True, size=128, modTime=1646936449, uri=u’/Users/Doufer/odrive/Closet Store’, contentTag=None), remoteUri=None"]) → SyncAdapterRequestException(code o_ILLEGAL_ADD_FILE caused by odriveRequestException(code o_ILLEGAL_ADD_FILE - Cannot add folders to this folder.))
2022-04-08_01:06:00PM 123145496715264 123145530368000 RAISED apply_remote_add_folder([u’parentUri=/‘, u"localAttributesTree=localAttr=FileAttributes(id=u’16777223:17422542’, name=u’Closet Store’, isFolder=True, size=128, modTime=1646936449, uri=u’/Users/Doufer/odrive/Closet Store’, contentTag=None), remoteUri=None"]) → SyncAdapterRequestException(code o_ILLEGAL_ADD_FILE caused by odriveRequestException(code o_ILLEGAL_ADD_FILE - Cannot add folders to this folder.))
2022-04-08_01:10:51PM None 123145597673472 RAISED apply_remote_delete_file([u’uri=/1aeb73fc-6037-4ecc-aaa7-32ed6d86fb11-55df1d61/1cNVpXICOs55iEjkAouBP7X3t1QBXZyvE’, u’parentUri=/1aeb73fc-6037-4ecc-aaa7-32ed6d86fb11-55df1d61/1LnP_qsRrbKhN561P5CKyNXotKEZ9k_eq’, u’o2Path=/Users/Doufer/odrive/Google Drive/Impressos/Belle Nutrir /IMG_8933.MOV’, u’trackingO2Path=/Users/Doufer/odrive/Google Drive/Impressos/Belle Nutrir /IMG_8933.MOV’]) → SyncAdapterRequestException(code GD_EDIT_PERMISSION_DENIED caused by GoogleDriveApiException(httpStatus 403 - {
“error”: {
“code”: 403,
“message”: “Insufficient permissions for this file”,
“errors”: [
“domain”: “global”,
“reason”: “forbidden”,
“location”: “file.permissions”,
“locationType”: “other”
2022-04-08_01:10:51PM None 123145597673472 RAISED _trash_item([u’o2Path=/Users/Doufer/odrive/Google Drive/Impressos/Belle Nutrir /IMG_8933.MOV’]) → SyncAdapterRequestException(code GD_EDIT_PERMISSION_DENIED caused by GoogleDriveApiException(httpStatus 403 - {
“error”: {
“code”: 403,
“errors”: [
“domain”: “global”,
Hi @douglasn,
Thanks for sending the diagnostic.
The subscription looks correct. If it wasn’t, you would get a message indicating that you need to upgrade to Premium, and it sounds like you are not seeing any messages.
As a test:
I got this message wen tried to set auto unsync…
Went I do right-clicking on a folder the unsync/sync or any odrive options didn’t showed up.
Just Uploading and Delete functions, I can only sync files and folders with double click…
I’ll have access to the computer on monday to make the tests you asked…
Thank you, for the support ![]()
Hi @douglasn,
It sounds like the context menu options are not showing-up, so that is what we will address first.
It may be that something is interfering with the Finder extensions, or they’ve been disabled. You can check this by doing the following:
Just let me know if you have any questions.
