There was no google cloud sync with my local desktop folder. I just want the local folder to receive the data from the cloud. The OneDrive folder receives all data normally. This is just happening with GoogleDrive. Does anyone know what might be happening?
Hi @centralizador.backup,
You are trying to right-click->sync a folder in Google Drive and it is not syncing?
Can you attempt the sync again and then send a diagnostic from the odrive menu so I can take a look?
Can you also provide the path of the folder you are trying to sync?
