Creating a seperate topic for this issue.
I’m not entirely sure if odrive is the culprit here, please assist in eliminating other factors.
We’re experiencing problems where newly created files and folders on the local storage (which uses odrive to sync to google drive) suddenly disappear within about 10 minutes of creation. 30 to 60 minutes after that, the files magically reappear.
Example:
The entirety of the path S:\__PROJECTEN__\2020\2020_KW4\
is set to sync via odrive to our remote storage (Google Drive).
Today, I locally created the path S:\__PROJECTEN__\2020\2020_KW4\FLG Character\Aangeleverd\Test
at around 16:10. I copied 9 jpg files (from outside of an odrive synced path) into this folder.
Around 16:20, I noticed that the folder \Test\
and its contents disappeared.
The lines in main.log are:
21 Oct 04:14:52PM INFO Successful Upload for S:/__PROJECTEN__/2020/2020_KW4/FLG Character/Aangeleverd/Test/invicibruuuu.jpg
21 Oct 04:14:52PM INFO Successful Upload for S:/__PROJECTEN__/2020/2020_KW4/FLG Character/Aangeleverd/Test/leon-man-2.jpg
21 Oct 04:19:38PM INFO Successful Delete Folder (Remote to Local) for S:\__PROJECTEN__\2020\2020_KW4\FLG Character\Aangeleverd\Test
After this there is a gap of 10 minutes before odrive does anything else:
21 Oct 04:33:53PM INFO Successful Download for S:\__PROJECTEN__\2019\2019_KW4\[redacted]
(This is part of an ongoing recursive download, discussed in Odrive refusing to sync from remote to local storage)
No delete action was executed from the remote storage, at least not as I can see from the activity tab:
That’s just the last message of odrive creating the folder and copying the jpgs into it.
I expect the folder to locally reappear soon, as we’ve seen this happen a few times more in the past weeks. The problem was just so hard to chase because we haven’t been able to reproduce it, until now.
What could be the cause here? I also sent a diagnostic 30 minutes ago to be sure.
