Fine grained bandwidth management
It seems upload bandwidth management is not so flexible at the moment.
If set it to normal (which is default) it uses all of my upload bandwidth (which is 6Mbps), therefore it is significantly limiting my download bandwidth about 25-35%.
If I set it to limited it uses far too less upload bandwidth, which considers in impossible slow uploads.
It would be great if there would be an option to set a max. upload bandwidth. Since I can calculate myself, how much of my upload bandwidth I have to reserve to keep my download bandwidth unaffected.
Thank you.
best regards,
Phil
This would be great! I am having some problems too with my upload and download bandwidth when I set it to normal.
