I’m just absolutely sick and tired of this nonsense. These screenshots are DAYS of wasted time.
odrive for whatever dumb reason keeps on wanting to upload data that has already been uploaded to the cloud.
I’m currently trying to sync a folder path that is already synced to ACD… to Google Drive.
Everything looked good and fine until I moved some fresh videos into one of the folders and now everything is going downhill. To be more specific, everything looked fine and all synced up until I added a few fresh files.
Perhaps I messed up, but I did everything as normal as possible. Maybe the issue is with having a folder structure synced to 2 different cloud services? But why is it these files just keep on re-uploading over and over?
This is odrive prod 6230. This is odrive installed on a fresh install of Windows 10. I’m sickkkk of these issues. I just got done download a ton of data and uploading (offloading) it to the cloud. If odrive can’t handle big data then okay. I’m fine with that. I’ll look elsewhere. odrive by every single glitch I come into simply can’t seem to handle large volumes of data.
I’m not even going to bring up the snail speed of future features. Stability is still an issue.
Hi @christianorpinell,
Odrive will upload if any changes to size or date are detected. You mentioned that you are syncing a single path to two storage clouds. Can you tell me how you are doing this since we don’t support this natively in the app?
Can you also send a diagnostic from the odrive tray menu?
No changes should have be done to these files. It’s a Adobe Lightroom folder of RAWs and PSDs.
I sent the diagnostic.
I’m syncing a folder to that is nested in the same way to both ACD and Google Drive. However, I think I did. But now that I think about it, something may have gone wrong with odrive before.
Here are the events in order.
Install fresh Windows 10
Re-Sync folder path to ACD with odrive, and it apparently took days to “connect” but there seemed to be moments where it actually uploaded data (which is should have, but I ignored it). This Re-Sync took place about 3 weeks, or so ago.
I noticed that this main folder no longer was in sync with ACD, I wonder if it had to do with the fact that I changed a folder name within odrive. If folder name changes breaks sync (inside of odrive web control), that should be known and prevented.
I must have ignored it and carried on. Then about a week after point 3, I decided to sync this folder to Google Drive.
I right click and sync to Google Drive (in the back of my head I wondered if this should technically not be possible since I half-thought it was already synced to ACD).
Everything was synced to Google Drive perfectly, and data seemed to stop uploading / finish uploading, I add like 2GBs of videos and hell breaks loose.
It was no longer sync’d to ACD (which is fine, I’m migrating), so that brings us to what should have still been a rather straight forward sync. (I realize that today)
I’m thinking it could just be data size from a single folder, but if distributing the data load across folders is the answer, then what is the recommended cap? I wish I knew, because I kind don’t want to keep the, “oh wait, odrive can’t handle this amount of data” thought process always going through my head.
If I create 5 individual folder all individually synced (point to) to odrive is that any different in overhead than 1 parent folder that has those same 5 folders?
Yes. This will break the sync-to-odrive sync relationship, since it is path-based. If the folder was renamed then the original name would be shown in the “sync to odrive” list as “missing”. The diagnostic shows two folders in this state:
D:/_ _ _Files Synced to ODrive (backup)
D:/ODrive Offset
The new folder names would not have a sync relationship associated with them, which is why you were able to select the “same” folder for Google Drive.
The diagnostic was pretty short, so I’m guessing you restarted odrive before sending? I don’t see any items in waiting or actively uploading at the time of the diagnostic, but it is in the middle of a scan.
Are you still seeing already-sync files re-uploading? For the ones that in the screenshot you posted above, these files were already synced to Google Drive and then started re-uploading on their own?
Unfortunately I would need to see another diagnostic that captures the spontaneous re-upload occurring to see what may have triggered it.
I was, but just when I try to prove it, it seems to now have stopped. Restarted several times now it seems normal now.
Yes, the ones in the screenshots were examples of re-uploading, pre-existing files.
I’ll be on the lookout if it happens again.
So renaming a folder inside of odrive web panel, or through Google Drive will break the sync relationship, but renaming it from Windows should be fine. Sounds like a stupid question but thought I would still ask.
Note: As of right now everything seems to be back to normal operation.
Not stupid at all. Renaming on either side will break the relationship. The only difference is: when you change it locally and then click on the link listed in the “sync to odrive” section in the odrive menu, it will let you find the folder again. If you change on remote you are not given that option.
Good to hear. Just let me know if you hit it again and I can try to figure out why odrive decides to upload.
