I’m having some issues recently with my AWS S3 bucket in Odrive.
I can’t synchronize or even delete files that were already correctly synchronized some time ago. I just get a message saying “Unexpected error”, and sometimes not even that .
Can you please tell me what the problem may be? I’m having the exact same behavior in both Windows and Mac builds. I can send you my diagnostics file if you want.
By the way, I managed to get an older version of Odrive for Mac (5719) and it works perfectly with that, so I would also like to ask you if there’s a place where I could download older binaries at least as a temporary workaround.
Thanks for your prompt reply! I’ve just sent you the diagnostics. Sending you the paths privately.
Please let me know if you need anything else.
