What’s the fastest way to connect and use local drives connected to a mac running OSX server? You guys have the ability to connect via FTP, WebDAV, SFTP, and odrive File Server. So far, odrive FIle server seems like the fastest technology to use. Can you confirm?
It should be very fast (fast enough for most use cases) if you connect over the LAN, using the private IP of the system. It is easy enough to setup that you should give it a shot and see how it works out for you.
