Extended Attributes - Tags MacOS
Hello. checking the forum from 3 years ago you didn’t support extended attributes like “tags”. So I’m checking back in 2022 to see if you are planning to support them? Extended attributes tags and other metadata are becoming more commonplace and regularly used in daily workflow. Dropbox fully supports.
Any hopes of getting tags supported by Odrive?
Here Here for Tags within ODrive! Definitely mission critical (after iCloud support :slight_smile: )
Checking back in before the end of 2022 about support for extended attributes like “tags”. Please support them! Extended attributes tags and other metadata are commonplace at this point and regularly used in daily workflow. Dropbox fully fully supports.
Please support tags in Odrive!
