Encrypt Folders Auto Sync
Hi wanted to ask if i need to reboot my pc will my files sync auto start were i left off using encrypt folders
Yes, your files will start getting synced automatically (were you left off) after your system reboots and odrive app launches on startup.
You can also right-click → refresh inside folder to kick off refresh request which will sync contents between storage and local machine, but won’t be needed since odrive look for files / folders which are yet not synced to storage periodically.
Asif
Okay Thanks AsifNisarr
