I’m one of the elder users, and I cannot Sync and Unsyn any more.
Hi @antonioc,
Can you provide some details on the problems you are seeing and also send a diagnostic from the odrive tray menu?
Hi Tony.
Thank you for your answer.
You and me are what we call in Spanish “tocayos”, what ir means that we have the same or similar names.
Perhaps what I want to do it was never an available feature , and the problem it’s just I have never tried it before.!
This is the case (image attached)
Have a folder with a number of folders in it. What I’m trying to do is select several folders (more than one), right click, and choose Sync, or “Unsync” for that group of folders.
Antonio
Hey @antonioc,
- Unfortunately you cannot multi-select folders for a right-click->sync action.
- You can multi-select files for right-click->sync
- You can also multi-select files and folders for right-click->unsync
For the folders you want to right-click->sync, you will need execute those individually
Just let me know if you have any questions on the above.
Thanks very much Tony!!!
I’m very, very sorry for my confusion.
Just one more question. If I want to know in a “folder tree” what files are not synced, can i use just a “dir *.cloud /s”?
Hi @antonioc,
Yes you can look for any items that have a .cloud or .cloudf extension.
Thank you very much!
