I discovered it just recently after tweaking my dual screen setup from (horizontal) side-by-side to (vertical) screen-over-screen. I have my taskbar attached to the top edge of the bottom screen (1). When I click the odrive icon it opens the panel upwards, into the top (2) screen. A small but really annoying issue. Would be great if you could find a fix.
Hi @idesignwebsites,
I have created a report for this on our internal tracking system. It may be a tough one, so Iām not sure if/when it can be addressed, but we appreciate the report.
Hi @Tony! Thanks for having a look into this. This is certainly not a critical bug, so no pressure.
