As per description, however the slashes are actually indicating subfolders, it’s not slashes in their names.
Can anyone help?
Thank you.
Can anyone help?
Thank you.
The operating system is OS X El Capitan
Hi @dvd.pugliese,
Definitely odd if it has no slashes. Can you reproduce this issue and then send a diagnostic from the odrive menu. Can you also supply the name of the file that is being reported as having slashes?
It’s 3 folders. One of them is:
“5 The Stream API, how to build streams, first patterns”
I sent the diagnostic info as well.
Solved, the problem was with a couple of spaces at the end of the folder’s name.
Great! Thanks for the update @dvd.pugliese
