I find out sometimes downloads are slow but at other times they are quick. Why? Are there any regularities?
Hi @j.thalbach,
In general odrive will download files in the same way, so there should not be much variability on odrive’s side. Download speed can depend on lots of different factors, though, like internet performance, network stability/saturation, the state of the storage service, size of the file, other load on the system, etc…
What types of performance variances are you seeing?
Hello
It could be due to a few factors:
If you’re using Odrive during certain times of the day, the server load from the cloud service could vary, leading to slower speeds.
Thank you ! ![]()
Don’t, you should use the stable internet connection on the stable place to solve this problem.
