Does it understand duplicate files & mirrors?
In Google Drive, you can use Shift+Z to mirror a sample file in different folders. Its a mirror and does not take up space in google drive.
Does odrive know its a mirror and just locally place a copy? Or does it download original GB’s of files once again?
And if there is a normal duplicate file, both Google Drive & dropbox recognize and don’t redownload. So wanted to know how it works here.
Hi @key
odrive can see files that are linked in this way (“mirror”), but it does not have the ability to create these links from the desktop client.
I don’t quite understand the duplicate file question. Can you clarify that?
odrive keeps your files as placeholder files until you want to download them, anyway. So even if File A was in 3 different places in Google Drive, you don’t have to download them 3 times. If you did, however, it would be treated as 3 separate files each taking up space. The mirrored files are still connected by the Google Drive backend, though, so deleting one of the instances of File A through odrive would tell Google Drive to delete it from that particular directory. Google Drive itself tracks the relationship as a mirror, which in the back end would effectively delete the file from the other locations. This would come back down as a delete in odrive in the remaining locations.
So I’d expect that even though odrive doesn’t treat it as a mirror locally on your computer, you still need to be careful since the Google Drive backend will continue to do so.
From a disk space perspective, odrive should overall be a net disk space savings (depending on your usage) since you can leave files you don’t use as placeholders. Especially with the Unsync feature, you would get granular control over how much local disk space is used.
-Jeff
