Is it possible to disable the syncing of symlinks to odrive? I would like to avoid it syncing specific folder paths without needing to blacklist every folder under that path. And the best way I could think of was by using symlinks but it seems odrive tries to sync them as normal folders?
Hi @itzeddie,
It isn’t possible to disabling following symlinks, but the way exclusions work, you only need to specify the top-most folder of the structure you want to be ignored. Many users have done this by just prefixing the folder with a ~ character.
