Hi odrive Community,
We’ve got a couple of releases out for you which have various integration improvements, bug fixes, and optimizations.
Web and Server Release:
- Integration (Procore): Business Subscription customers only: show Specifications Tool, Drawings Tool, Photos Tool content in Project folders.
- These folders are read-only. You will need to use the Procore webapp to make changes as part of the Tool’s normal intended workflow.
- Disable sharing and encryption on certain large enterprise accounts.
- Miscellaneous bug fixes and other improvements.
Win v. 7012 / Mac v.7125:
- Integration (Procore): Rate limit handling improvements.
- Integration (Multiple sources): Upload and partial/incomplete upload handling improvements.
- Integration (Amazon Cloud Drive): Rate limit handling improvements.
- Integration (SFTP): Bad connection handling improvements.
- Automatic Empty Trash: make cleanup more aggressive and reduce the time to clear trashed items. Response time should be reduced from about 2 minutes or so down to about 45 seconds or so.
- Backup fixes: handle case changes in files and folders.
- New premium advanced config settings to disable sync applying either remote or local deletes to files and folders:
disableRemoteItemDeletesdisableLocalItemDeletes
- Fix for the existing disable remote/local updates settings to include XL and Encryption files.
- File overlay badging tweaks.
- Logging improvements.
- Other bug fixes and improvements.
The new desktop builds can be downloaded from the usual download location if you want to try them out before they make it to the app autoupdater.
Let us know if you’ve got any feedback or questions about anything above.
Warm regards,
-Jeff
