Hi Odrive Community,
We have a couple of releases today with some various integration improvements and other adjustments.
Win v.7213 / Mac v.7353:
- Integration improvements:
- Google Cloud Storage: during linking, correctly determine if Google Cloud Storage link doesn’t have the right scopes.
- Procore: tweak rate limit logging
- Autodesk: fix to use nameinstead ofdisplayNameproperty, by default.
- OD4B: correction for domains starting with “me”
- Advanced config option to perform auto-unsync using “last accessed” time.
- Set autoUnsyncUseAccessto true to enable.
- Set
- Better handling of .eml and .nws files…
- Ignore a local date modified change on only .eml and .nws if the size remains unchanged.
- CLI: Added session expiration notification
- Urgent notification warning if a CRC file error is encountered (generally indicates a failing hard drive)
- Unsync: Logging to include more detail
- Unsync: Change unsync interval to 4 hrs.
- Other misc fixes for logging and messaging
Web and Server Release:
- Adjusted Microsoft login button text to be more descriptive.
- Integration changes:
- Refine Autodesk and Dropbox token expiration during upload
- Autodesk: change exception reason/message for token refreshed but previous fragment not uploaded
- Autodesk: default to using nameproperty instead ofdisplayName
- Google OAuth scope handling changes (no longer request GCP scope automatically for a user and rely on the included scopes mechanism again)
The installers are available from the download page . Let us know if you encounter any issues or have feedback.
-Jeff
