Deinstall guide
Hi there
I tried to install odrive on Linux. Using all the commands. Not happy with the integration on linux mint.
Please tell me the commands to deinstall it. Literally 0 experience and still learning. I just want it gone from my computer. Thank you
Hi @Rayd,
The Linux odrive agent is under ~/.odrive-agent. If you remove that folder that is all that is needed to remove the odrive agent from your machine.
