I was having issues with the odrive client not syncing the changes on my local drive to G Drive. The client was started but did not have any options in the context menu. I reinstalled/upgraded the client, but that did not help either. So, I deauthorized the account from the client, then authorized it again. Now, the files that were pending sync up to G Drive are gone. Is there anyway to recover those or am I SOL?
Hi @stuartj,
When you deauthorize, the current odrive folder is renamed to a backup name (odrivebackup-[current date and time]) and a new odrive folder is created.
If you check your user home folder, do you see the odrivebackup folder?
Found it! Thanks, not sure why I didn’t think to check there. I’m all set.
