Hi @keith,
There doesn’t appear to be a general issue as I am able to upload to my Google Cloud Storage accounts.
Are you testing with both the web client and the desktop client?
Are you seeing this with all files sizes?
Are you able to download?
Hi @keith,
Quick update. I am seeing there may be an issue on one of our nodes that could be causing issues with uploads via the web browser, although the desktop client should be fine.
We have taken that node out of rotation, for the time being. Let me know if you are still seeing the issue.
Hi @keith,
If it was the webclient it may have been this specific node you were hitting. Routing is based on latency, so it may have been the one you were using. When we took it offline you may have still been hitting it, which is why your downloads started to fail too. We’re taking a look at it now.
For support, it is something we are looking at (expanding the support department and “off hours” response time). My apologies for the delay on this one. The way this node failed was subtle, so it wasn’t picked up by our automated monitoring.
