CLI odrive.exe mount command does not fold drive-letter to upper-case
I am using the odrive CLI. I have discovered that the odrive mount command does not fold the drive-letter to upper-case (I am using odrive.exe rather than odrive.py)
Consider:
– First, notice that things are working properly
E:\odrive-home>odrive status --mounts
E:\odrive-home status:Active
status:None
E:\odrive-home>odrive unsync "Amazon Cloud Drive"
E:\odrive-home\Amazon Cloud Drive.cloudf
E:\odrive-home>odrive unmount E:\odrive-home
Successfully removed mount with path: E:\odrive-home
– Now mount using a lower-case drive letter.
E:\odrive-home>odrive mount e:\odrive-home /
e:/odrive-home is now synchronizing with odrive.
– Notice that the drive letter case is preserved by odrive, rather than being folded
e:\odrive-home status:Active
status:None
– Notice that commands which previously worked now fail.
E:\odrive-home>odrive sync "Amazon Cloud Drive.cloudf"
Unable to sync Amazon Cloud Drive.cloudf. This file is not inside an odrive folder.
– Remount with upper-case drive letter, and things work again.
E:\odrive-home>odrive unmount e:\odrive-home
Successfully removed mount with path: e:\odrive-home
E:\odrive-home>odrive mount E:\odrive-home /
E:/odrive-home is now synchronizing with odrive.
– The good news is that otherwise, Windows filenames seem be to correctly matched case-insensitively.
E:\odrive-home>odrive sync e:dropbox.cloudf
E:\odrive-home\Dropbox
@rbdaviesjr
Wow, thanks for providing that level of detail. We’ll note this as a bug to be fixed in a future release of the odrive.exe executable.
-Jeff
