Can't sync Unexpected error. Please try again later
odrive%20Forum%20-%20Mozilla%20Firefox
It partially sync then give this error. How can I “debug” or get any clue to figure out what is going on?
Hi @ulisses.b,
Can you trigger the error again and then send a diagnostic from the odrive menu? Once you do that, let me know and I can take a closer look.
Sure. Done!
PrtScr%20capture
Hi @ulisses.b,
odrive is getting a 500 error code back from the WebDAV server. 500’s are generally unexpected exceptions, so they do not provide useful details on what the issue is.
The file it is happening on is:
Ulisses/Meus arquivos recebidos/WWWBCC/FINAL/phpBB/ADMIN/admin_board.php
Thanks, I’m going to check this path
I have moved the folder WWWBCC to another path and tried to sync again. Same error. Sending diagnostics again
Hi @ulisses.b,
It is still showing the same error for this path:
C:/odrive/MyCloud/Documentos_Indepe/Ulisses/Meus arquivos recebidos/WWWBCC/FINAL/phpBB/ADMIN/admin_board.php
Can you try browsing into that area to see what you see?
Also, it may help to sync the folder without downloading. So when you right-click->sync, slide the slider all the way to the left for “nothing”.
I’m going to try to move this path: MyCloud/Documentos_Indepe/Ulisses/Meus arquivos recebidos/WWWBCC
to another location
Without this folder: WWWBCC it works
Next we need to see why it rejects to sync this folder
Hi @ulisses.b,
Yeah, unfortunately the error coming from the WebDAV server is generic, so I don’t know why it doesn’t want to allow odrive to download it. Maybe it has broken symlinks or permissions restrictions?
