When I try to open the odrive context menu to empty the trash, when I hover over trash the option to empty does not appear.
Hi @ratchet132,
This is likely due to there being too many items in the trash for the UI to render properly. Are you running on a Windows or Mac system?
Windows, it works fine on my Mac, but since the files were deleted on my Windows PC it won’t allow me to delete those files on the Macbook.
Hi @ratchet132,
Since the odrive menu is not being responsive, we can try using the CLI to give us some insight.
To use the CLI commands on Windows:
Open up a command prompt by clicking on the Windows icon in the taskbar, typing “cmd”, and then clicking on “Command Prompt”.
Once the command prompt is open, copy and paste the following command in (all one line) and hit enter. This will install the CLI for us to use in the next commands. It could take a minute or two to complete:
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";(New-Object System.Net.WebClient).DownloadFile(\"https://dl.odrive.com/odrivecli-win\", \"$comm_bin\oc.zip\");$shl=new-object -com shell.application; $shl.namespace(\"$comm_bin\").copyhere($shl.namespace(\"$comm_bin\oc.zip\").items(),0x10);del \"$comm_bin\oc.zip\";}"
This second command will query the odrive desktop status:
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";$(& \"$o_cli_bin\" status);}"
Then you can get detailed status on specific areas with these commands:
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";$(& \"$o_cli_bin\" status --uploads);}"
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";$(& \"$o_cli_bin\" status --downloads);}"
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";$(& \"$o_cli_bin\" status --trash);}"
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";$(& \"$o_cli_bin\" status --waiting);}"
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";$(& \"$o_cli_bin\" status --not_allowed);}"
The “status --trash” command will show you all of the items that are being held in the odrive trash. You can look through these, just to make sure nothing stands out.
The “emptytrash” command will tell odrive to empty the items in the trash:
powershell -command "& {$comm_bin=\"$HOME\.odrive\common\bin\";$o_cli_bin=\"$comm_bin\odrive.exe\";$(& \"$o_cli_bin\" emptytrash);}"
