Hi! I’d like to just make my Odrive the same as my default docs folder on my mac and my windows pc. And I’d like to have that be an Encryptor folder so that the cloud storage version is encrypted. Is that possible? if so, how?
Hi @gelobter,
You can create a sync relationship between your Documents folder and a location in your remote storage using the “sync to odrive” feature.
You cannot currently combine encryption with this feature, although that ability is expected in the coming months.
For now, Encryptor folders are their own structure and can’t be linked with external folders.
