I have an existing external hard drive that is synced with my Amazon Drive account. Is it possible to move these folders onto another external hard drive and still keep the relationship between the folder AND Amazon Drive?
If not, is there a way to re-link these without creating duplicate files on Amazon Drive?
Hi @kevindsimon,
If you “remove sync” on the current synced folder, move the data over to the new drive, and then setup the same sync relationship on that new drive (make sure the folders are all named the same), odrive will merge the local and remote data. In this case it should see that everything is already synced, but it will take some time to go through all of the data.
Let me know if you have questions about the above.
