Brandable links
Brandable links - Is it possible with odrive? 02-08-2020 00-18-12
Problem Description: I wish to create brandable links with odrive
Step 1. The following file is being shared.
2020-08-02_00h19_23
Step 2. The link being shared is copied.
The copied link has the following format: https://www.odrive.com/s/17d28bc1-e682-4fff-8993-5b5de88f8d53-5f25ba24
Quick Question - Instead of the above mentioned link, is there any option to have brandable links?
02-Aug-2020 Sun, 12:25 AM
Alternatively, is there any option to set password options and / or expiry dates from within odrive windows desktop client?
Anil (Advocate)
P: +91 7095 776633 (India)
P: +1 (408) 462 7600 (USA)
Whatsapp Click Here
Schedule A Meeting - click here now
Confidentiality Notice: This message and any files transmitted with it are for the sole use of the intended recipient(s) and may contain confidential and privileged information.
If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
Hi @anil.satyagraha,
Could you provide an example of the type of branding you would like to see for these links?
What is your use case for this, so that we can better understand the need and the potential solution?
I think it’s so important to send documents to another companies
This is something we will definitely consider.
We have another product called LeapFILE that is dedicated to secure file transfer and offers branding, if you want to take a look. https://www.leapfile.com
