Thanks for odrive. It took me a few goes to get it set up and working via Bash scripts (on Linux Mint 18), but I now have it set up so that I can easily sync with various cloud services on demand. I saw some discussion about odrive and encryption, but I find that using Borg Deduplicating Archiver in conjunction with odrive meets my needs - worth looking at for anyone who wants their stuff encrypted before syncing. By way of a small token of thanks, here’s the snippet of script I’m using to get a continuously updating display of the syncstate which includes checking for keyboard input (P or Q) to pause or quit. The pause is not a true pause because it just temporarily unmounts odrive, and consequently ‘unpausing’ is really a restart, but I think it’s better than nothing.
odrive_py="$HOME/.odrive-agent/bin/odrive.py"
odrive_mountpoint="$HOME/mnt/odrive"
tput civis -- invisible
while $(python "$odrive_py" syncstate "$odrive_mountpoint") != *Synced*
do
tput cup 3 0
echo
echo "Press P to Pause, Q to Quit"
if read -t 0.2 -n 1 keypress; then
if [ "$keypress" = "p" ]; then
# Temporarily unmount odrive
python "$odrive_py" unmount "$odrive_mountpoint"
read -p "Press any key to restart sync" -n1 junk
clear
# Remount odrive
python "$odrive_py" mount "$odrive_mountpoint" /
elif [ "$keypress" = "q" ]; then
break
fi
fi
sleep 1s
done
# Unmount odrive
# Shut down sync agent
python $odrive_py shutdown
fi
Note that it requires the sync-agent to be running and the odrive_mountpoint to be already mounted. It works for me, and anyone is welcome to use or adapt it for their own needs.
