"Amazon Cloud Drive" appearing in "Not allowed"
I used to have Amazon Cloud Drive then migrated away from it (but when I first signed up to ODrive and until now - I have to use “Login with Amazon” option).
So now in the sync menu, Amazon Cloud Drive appears in the “Not allowed” list.
How do I remove it?
Hi @budowski ,
You can unlink the Amazon storage link in your Odrive account from the web client. The storage link is unrelated to the login.
Go to odrive | Sign in
Click on the ‘V’ icon next to the storage and select “Unlink”
Thank you, but it’s already NOT in the list (only GDrive and Dropbox)
Hi @budowski,
Ahh! Then you can just move the folder out of odrive, and delete it when you are comfortable doing so, if there is nothing in the folder that you want to keep around.
