I have tried to set the offline targets to be only a day old… its obviously not worked, and i probably have 200 gig that i can offline but it hasnt… suggestions?
the upload finally completed. I sorted by size and did a manual unsync.
HI,
We are taking a look at the behavior. In the meantime, can you try toggling the auto-unsync setting (set it to something else then set it back to your desired setting) and see if it kicks-in after a couple of hours?
