Sync dialog box does allow for user to select size and check for other sync options. Please fix this bug. I have a screenshot but not able to add. Thanks, Dean
Hi @deanneese,
Can you create a shared link to the screenshot and then post the link here so I can take a look? I am not clear on what you are seeing.
