Sync Delete problems
I am having trouble getting odrive to sync delete my Amazon Cloud Drive. At worst, I get a cryptic error message immediately that says:
Unable to sync delete [filename]
Please check your network connection or manage your proxy settings.
I think my network connection and proxy settings are fine. Everything else is working. However, could you provide settings so that I can check?
Or, odrive sync deletes one or two files and then gives me the same message. Having to restart sync delete everytime this message appears is very time consuming.
Please help me resolve this issue. I am using prod 6239 on Windows 10.
Hi @dlarue65,
It sounds like Amazon is throwing exceptions during this process, which is halting the delete operation. Can you send a diagnostic from the odrive menu so I can take a look?
It looks like Amazon has corrected the problem. I wanted to sync delete before I sent the diagnostic. It deleted nearly 200 items before it stopped and that was because it exceeded the Cloud drive request limit. Thanks for your attention but it appears to work now.
Glad to hear it @dlarue65. Thanks for the update!
